Will EGR not hooked up cause lean condition?
  • Thread starter Thread starter mooktank
  • Start date Start date Dec 5, 2004
M
mooktank
237
  • Dec 5, 2004
Just wondering if you let your EGR suck in fresh air would you run lean at part throttle? So this is not a good idea then?
04-SVT
53
Las Vegas, NV
Dec 5, 2004
  • Dec 5, 2004
I am pretty sure if you are letting air in at the EGR, it will be unmetered air going in your engine, so yeah I would guess it would be lean.
fiveoboy02
17
  • Dec 5, 2004
If it was open constantly, you'd also have the equivalent of a vacuum leak.
Funanin
356
Horsham, Pennsylvania
Dec 5, 2004
  • Dec 5, 2004
yea what they said, it needs to be metered otherwise the motor wont know its there and wont compensate the extra air with extra fuel.
HISSIN50
34
129
Dec 5, 2004
  • Dec 5, 2004
plus EGR gasses are supposed to be inert.
R
raph130
517
  • Dec 5, 2004
HISSIN50
34
129
Dec 5, 2004
  • Dec 5, 2004
if one blocks off the EGR - i would go burn a chip so that the puter does not dial in a ton of timing, thinking that the inert gasses are entering at part throttle. not everyone has this problem, but i would not delete the EGR w/o letting the puter know.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 5, 2004
  • Dec 5, 2004
The computer adds spark advance to compensate for the recirculated gases and the slower rate they burn at.
The EGR shuts off at Wide Open Throttle (WOT), so it has minimal effect on performance. The addition of exhaust gas drops combustion temperature, increases gas mileage and reduces the tendency of the engine to ping.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 5, 2004
  • Dec 5, 2004
To add to jricker's and hissin's comments - removing the egr valve, without altering the ecu accordingly, can cause a mixture that's too lean with too much timing at part throttle - leading to lean conditions and detonation. I used my Autologic chip to turn off the egr function in the ecu when we removed the egr.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
