  • 1994 - 1995 Specific Tech
Will I have problems getting an alignment?
  • Thread starter Thread starter mystang94gt
  • Start date Start date May 18, 2005
mystang94gt
951
Bay Area, CA
May 18, 2005
  • May 18, 2005
I have ford racing lowering springs and I havent bought CC plates. Are they going to be able to align my car without the CC plates? I plan on telling them to just get it as close as they can. Has anyone else had problems with this?
S/CBlack95GT
2,018
Tampa Palms, FL
May 18, 2005
  • May 18, 2005
They will be able to do the toe, but they can't to much with the caster or camber. You can get a set of great C/C plates for under $180. Getting some would make sense so you set in a ton of positive caster, which will make the car feel better.
MysteryMachine
1,835
Parkesburg, PA
May 18, 2005
  • May 18, 2005
Don't try to get UPR 4 bolt ones they are out of stock God only knows when I'll get my damn parts
mystang94gt
951
Bay Area, CA
May 18, 2005
  • May 18, 2005
Well my tires now are wearing excessively on the outter edge. So I wanted to get an alignment done in hopes of extending their life a bit since they are relitively new. I just wanted to try and get it aligned without the CC plates since I cant afford them at the moment. Is it even worth doing?
oh and can you elaborate on toe, caster and camber and what they are exactly? (basically which ones which) thanks
94-302-vert
1,947
NE CT
May 18, 2005
  • May 18, 2005
I did the FMS C-springs and when I asked this question it was up in the air... some needed them others didn't... So I bought some.
Chris
S/CBlack95GT
2,018
Tampa Palms, FL
May 18, 2005
  • May 18, 2005
It all depends on how much play are in your stock plates. They may be able to move them enough to get the camber right.
mystang94gt
951
Bay Area, CA
May 18, 2005
  • May 18, 2005
Chris
Well Im hoping that I dont cause I cant afford them for a few weeks and I want these tires to last some. thanks for the input.
mystang94gt
951
Bay Area, CA
May 18, 2005
  • May 18, 2005
Well I think I am going to give it a shot since I cant afford the CC plates right now. Hopefully they can at least get it better than it is right now.
S/CBlack95GT
2,018
Tampa Palms, FL
May 18, 2005
  • May 18, 2005
Yeah, the toe is the main concern. With the C springs you should have a tad too much negative camber..your tires will look like this from the front / \.... However, with only a 1.25 inch drop it shouldnt be much more than 1.5 degrees, which isnt bad.
94-302-vert
1,947
NE CT
May 18, 2005
#10
  • May 18, 2005
  • #10
This site has some decent info on the alignment:
http://www.steeda.com/PR/Mustang/Alignment/alignmentbasics.htm
I haven't paid for an alignment yet as my front tires were junk before... so why try to save them.... Play around with it. I had a simmilar problem (plus car was pulling left) I out a little more negative camber on the drivers side wheel and it tracks strait and the tires seem to wear evenly.
I actually painted across the width of them and drove up the street checking to see where they were wearing fastest a few times. so far no problems.
When you lowered it did you move the C/C plate at all? Looking from the front make sure your tires lean in at the top slightly.
There are a few decent sites on how to do a driveway alignment if you have the time... Sounds like it takes about 4 hours...
Chris
mystang94gt
951
Bay Area, CA
May 18, 2005
#11
  • May 18, 2005
  • #11
Chris
You know I cant remeber adjusting the CC plate at all. I did front struts the same time I did the springs but I dont think I ever messed with the CC plates. Just unbolted the top of the strut and pulled it out. Right now my tires do lean in at the top slightly. And the drop really wasnt much at all thats why I was hoping I could go without the CC plates for a while. Thanks guys I think I will go and get it aligned sat morning.
MysteryMachine
1,835
Parkesburg, PA
May 18, 2005
#12
  • May 18, 2005
  • #12
AH i figure i need it aligned after i put all my new parts on anyway so hopefully its good enough to drive to the shop and they can deal with it. I just hope they have the bumpsteer checker thing
mystang94gt
951
Bay Area, CA
May 18, 2005
#13
  • May 18, 2005
  • #13
Bumpsteer checker? Are you running 275's all the way around? I have em out back and 245's up front. Since I cant rotate them I really want to make sure I can get the most out of the front ones since I cant just throw em on the back and roast em once they get worn.
MysteryMachine
1,835
Parkesburg, PA
May 18, 2005
#14
  • May 18, 2005
  • #14
yeah a bumpsteer gauge? It talks about it in the instructions of the kit. And yes i have the 275's all the way around
go-stang5.0
2,244
Glenview,Il
May 18, 2005
#15
  • May 18, 2005
  • #15
I run about 2.5 deg of camber daily and its fine. I do get a bit of inside wear but as soon as I rotate the tires the rear end wears them even. If the camber isnt noticable to you then its prolly around -1 and I wouldent worry about it too much. However CC plates are always a good investment. I recommend the MM 4-bolt ones. Cant go wrong with those. There cheaper than others and are prolly the best ones you can get.
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
Resolved Ford 302 damper issue
  • James S
  • Aug 8, 2026
  • Other Auto Tech
Other Auto Tech Aug 8, 2026
James S
J
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
