will this work for me
  • Thread starter Thread starter Roland69
  • Start date Start date Apr 26, 2006
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 26, 2006
  • Apr 26, 2006
can I put a gauge cluster from a 1992 Ford Mustang 2.3L LX work in my car (88 GT)
sgarlic
3,085
Apr 26, 2006
  • Apr 26, 2006
Nope, 92's have airbags, different shaped bottom.
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Apr 26, 2006
  • Apr 26, 2006
Can swap the part of the dash with the light & emergency blinker switches so it fit. Also have to swap circut panels on the back of the clusters along with the tach's for it to work properly and so that the tach reads correctly.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 26, 2006
  • Apr 26, 2006
Yeah- no tilt steering either dedgummit!
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 26, 2006
  • Apr 26, 2006
I have tilt
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Apr 27, 2006
  • Apr 27, 2006
Had to do this in an 87 coupe when we swapped a newer style black interior on a 4 to 8 EFI conversion.. We put all the dash items in the car, but kept teh 87 wiring and swapped the plastic circut board on the clusters to make it work.
W
wazazzle
618
In the dumpster behind McDonalds. WA
Apr 27, 2006
  • Apr 27, 2006
That's a big NEGATIVE.... over! I just fiqured out today why my tach was running so high, about 2x what was actual rpm. I had a 6k tach 4cy cluster. Which I found out anytime you have a 4cy tach in a v8. Your tach will be off big time a couple grand. As I was explained by my ford tech buddy who brought in a digital tach and discovered this. The 4cy tach reads twice the rpm because your v8 is sending 2x the sparks. Your tach cluster can not distinquish the difference. It will just assume you have a 4cy that is revving into higher rpms, which is not true. I believe the early 80's tachs (which you wouldn't be able to use anyways) did have a 4/6/8cy switch so you could change it. But looks like you'll have to buy a v8 cluster. Btw if it's unclear 87-89 will not work with 90-93 due to airbags, wiring connectors (unless you repin) and because the depth at which the cluster sits inside your dash... guess you could call it "depth set" will not fit. If you're looking for a 140mph 7k tach, you need one specifically pulled from a 89 gt/lx/nb v8.
M
Gauge cluster
  • MadMatt7
  • Nov 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 9, 2026
keel
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
C
New member from NJ
  • Calyp5.0
  • Sep 25, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 25, 2026
General karthief
9
Engine 2.3 fox body upgrades from sn95
  • 92ponyboy
  • Feb 20, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 25, 2026
NXcoupe
N
