  • 1994 - 1995 Specific Tech
window bushing problem
  • Thread starter Thread starter chaos254
  • Start date Start date Sep 18, 2006
chaos254
467
NJ
Sep 18, 2006
  • Sep 18, 2006
I was having problems with my window getting stuck so I finally got around to taking the window motor apart. The 3 bushings were completely destroyed so I went to the autopart store and got 3 more from the help section but when I put it back together... it seemed like the 3 bushings were too big. They dont sit in the white gear flat because of some little lip at the bottom of where each bushing is supposed to go. I did finally get the metal gear back on by hitting it with a hammer until i could get the gear clip back on but now that I put everything back together the window wont even budge. Could I have gotten the wrong bushings which is causing the motor to bind? I used the writeup in faq but it didnt really help with how your supposed to put the bushings back in. I'm gonna take the motor back out in a little bit. any suggestions would be great.
Bosko5.0
1,067
longwood, FL
Sep 18, 2006
  • Sep 18, 2006
i Had same problem i just used a razor to trim them down a bit so thay slide in easy, works beter than other motor
chaos254
467
NJ
Sep 19, 2006
  • Sep 19, 2006
did you just trim the height? or the width as well?
Paint and Body Window bushing
  • JD1964
  • Aug 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 19, 2025
General karthief
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
