Window Motor Question
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Okay well my drivers side window wont roll up. Theres 12 volts coming from either wire from the switch which is good means the switch is working, but that connector that comes from the one button down module when I check that I only get one current when I push up. Either of the prongs dont respond when I push down.
Let me draw something
Code:
SWITCH
white/black wire   UP   -   12 volts --------------  Regulator --- 12 volts
Yellow               DOWN  - 12 volts -------------   Regulator -- Nothing
ugh that didnt work either lol....hmm
well I get 12 volts from the wires correctly at the switch. After the switch and regulator there is a 2 pin connector that goes to the window motor. When I try to do the same test to that I do not get the right results. Is it a bad one button power down or a bad motor? How can I test the motor? I tried to bypass that one button down thing by taking a wire and connecting it directly to the motor from the switch but it didnt work even though those wires give off 12volts. Wow i'm horrible at writing this. How can I tell if my motor is bad, or my one button down thing? GRR
New question:
How the F do you get the window motor out with the window down? My hand barely fits, and it isn't budging. Does the window have to be up?
