Wiper Fluid only comes out driver side...
velocity
48
Colorado
Can anyone help with this issue. I have tried plugging the driver side to force the fluid out the passanger side but no luck. Anyone have the routing diagram for those lines so I can try to track down a leak or some other problem.
Thanks for the help!!
It does not seem as if the tube is plugged. I have tried blowing it out with a "can of air" and air comes out the driverside. I plug the driverside and blow into the passenger side again and nothing reallyl seems to happen. This does not make sense, because if there was a plug it would have to be before the split for the driver and passenger. But if that were the case, neither side should work.
I will try to find the end and unplug it this weekend and blow it out that way.
Anyone have any other suggestions I can try??
Thanks for the suggestions!
