Wire Question
  • Thread starter Thread starter BlackLX5.0
  • Start date Start date Jan 10, 2006
BlackLX5.0
76
  • Jan 10, 2006
I was wondering if you all might have a wiring diagram for a 91 mustang lx 5.0. All the wires are hooked up on my motor except for 3. Ones coming from the driverside of the intake and the other two are by the driverside fender.
Thanks :SNSign:
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 10, 2006
  • Jan 10, 2006
Your description is very vague. What kind of connectors are on the ends of the wires?
Diagram courtesy of Tmoss and Stang&2birds.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring and lots more… http://www.veryuseful.com/mustang/tech/engine
BlackLX5.0
76
  • Jan 10, 2006
Thanks for the diagram. I figured out which ones they were, except for two of them. They come off the driverside of the intake. It looks like the end of a sparkplug wire sort of, but its not. Thats the only two I got to figure out where they go.
Thanks :SNSign:
T
TheUser
1,859
Springfield, MO
Jan 10, 2006
  • Jan 10, 2006
the only ones I can think of are the connection for the Coolant Temp Sensor - stock location is the front drivers-side of the lower intake. Just to the right (if you're standing in front of the car) and down from that, you'll see a little cyclinder type of thing connected to an arm extending from the block - that's the oil pressure sender, which is what I think the other one is. Those are the only two connections I can think of that resemble a smaller version of a "spark plug connection" near the intake; the only other one like that is the top wire on the starter relay which comes from the ignition switch; the starter relay is located on the drivers side fenderwell just past the battery if you're standing in front of the car - the positive battery cable goes to it (along w/ a lot of fusible links and connections) and the other side is the starter wire, which obviously goes to the starter. There's a little "stud" on the top part, which has a "spark plug" like connection.
Good Luck!
BlackLX5.0
76
  • Jan 10, 2006
Thanks For The Help , TheUser, Would You Happen To Have A Pic Of Where They Go? Because I Looked & I Really Couldnt See Where They Plug Into. In My Oil Sending Unit, Its There But The Wires Are Missing Off Of It, Thats What Someone Told Me. Is It A Dealer Item Or Can I Get It At Any Parts Store?
Thanks :SNSign:
HISSIN50
34
129
Jan 10, 2006
  • Jan 10, 2006
Thanks :SNSign:
James and JR are great with the pics to help fellow stangers out.
The OP sender is available at parts stores (I think you have yours) and the sender just has one wire. You could just run a new wire and tie it into whereever you find what is left of the old one (solder the connection since it sends a ground pulse to the guage).
The S-terminal on the starter solenoid slides onto the top of the solenoid - there is a shiny 'bolt' post for it to go on.
Whoops - just reread James' reply - he covered all that. Oh well.
Good luck.
BlackLX5.0
76
  • Jan 10, 2006
Thanks everyone, I really appreciate everyones help :SNSign:
BlackLX5.0
76
  • Jan 11, 2006
Okay quick question, Where does #40 connect to in the car? Also #34 and #37?
Thanks lol
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
  • Mindseye007
  • Aug 16, 2026
Mindseye007
