Wiring Driving lights?
  • Thread starter Thread starter soontobefastfox
  • Start date Start date Feb 13, 2007
soontobefastfox
275
Troy, Michigan
Feb 13, 2007
  • Feb 13, 2007
I got the smoked ultra clear headlights with the driving lights that are suppose to be wired to the parking lights (they did not come with instructions). I have seen many people with them either in clear or smoked. Which wire for the + do you splice into? Thanks.
HISSIN50
34
129
Feb 13, 2007
  • Feb 13, 2007
Did you do the relay retrofit first? I would do that and then while the headlight switch is out, move your fog light power source (only energizing a relay coil at this point) to source power from the parking lights (a brown wire, IIRC. Test with your meter to be sure).
There's a decent article on the Corral about doing this. I'm sure someone will post it in a minute.
Good luck.
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Feb 13, 2007
  • Feb 13, 2007
The easiest way to find out which wire is hot when the parking lights are on is to use a multitester or light probe. This can be used if trying to find out which wire from the headlight plug. If you just go to the parking light bulb, and tap on to the wire that is not black or brown, that would be the one that will provide +12 volts when turned on. I would wire in a 12 volt relay between the power and the lights, it takes a lot of the stress off fuses.
The relay will have 4 wires attached to it. 1. ground, 2. constant power/accessory power 3. wire to lights 4. wire from parking light plug.
If you have any more questions, plz ask, I can try to go into more detail
soontobefastfox
275
Troy, Michigan
Feb 14, 2007
  • Feb 14, 2007
Good luck.
Where is this article on Corral?
HISSIN50
34
129
Feb 15, 2007
  • Feb 15, 2007
If I had the link saved, I would have posted it earlier.
http://www.corral.net/tech/maintenance/foglights.html
Good luck.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
