wiring help
  • Thread starter Thread starter mustangcobra93
  • Start date Start date Jul 29, 2004
mustangcobra93
928
  • Jul 29, 2004
I don't know much at all about the electrical system of our cars. Then when adding the zex kit, heater, purge, HI-6S, & shift light I don't really know what wires to splice for the 12 v power that is hot only when the key is on and during cranking. Right now its all (except for the purge which is not hooked up) connected to the radio power wire. I have been told this is not good, but I don't know were else to put it. Any suggestions for the electrical gods out there?
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Jul 29, 2004
  • Jul 29, 2004
Get some help from someone who knows how to do wiring work correctly - best advice I can give you!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 29, 2004
  • Jul 29, 2004
The best short term advise is to tap the Red/LT Green wire that supplies power to the ignition coil.
If you are familar with how to wire relays, make another post & I will give to some ideas on adding another fused circuit that only comes on with the ignition switch.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Jul 29, 2004
  • Jul 29, 2004
I don't think he wants to run the heater off that wire though
ss93cobra
1,422
Wilmington NC
Jul 29, 2004
  • Jul 29, 2004
The HI-6S comes with pretty good installation instructions as well including specific make diagrams, like Ford, Chevy, etc. Not easy to mess those up.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
