wiring problem
  • Thread starter Thread starter ponyboy762
  • Start date Start date Jun 20, 2006
P
ponyboy762
32
  • Jun 20, 2006
For about a month now, sometimes when I start the car, the motor will start but the starter will stay engaged. A little tap on the solenoid and the starter stops. I began by changing the solenoid, then the + and ground cables from the battery, and finally the starter to solenoid cable. None of the wires feel hot, and to my untrained eye everything looks the way it should. Any ideas would be usfull.
HISSIN50
34
129
Jun 20, 2006
  • Jun 20, 2006
When it sticks, have you been able to have a meter on the starter lug to see if the relay's energized while it runs-on?
If it is, do the same check at the S-terminal.
Good luck.
P
ponyboy762
32
  • Jun 20, 2006
There is nothing coming from the key switch, it's almost like it's welding itself together on the inside of the solenoid
Bolt on 5.0
302
Suffolk, NY
Jun 20, 2006
  • Jun 20, 2006
Is the solenoid new or replaced with a used solenoid?
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Turbo header Starter wire routing?
  • 387lx
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 3, 2026
387lx
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
