It's time to get this engine running!
I am working on the wiring for my starter and my alternator. The battery has been moved to the trunk and I have removed the wiring harness on the passenger side that connects to the computer (I'm running a carbed application here).
I am planning on running the following for the starter:
Positive wire from battery to fuse block post.
Another wire from the fuse block post to starter
I am running the Ford M11000-A50 starter
Question: Where does the smaller wire connect to in order to provide power to the solenoid? Does it go to someplace on the fuse block or into a part of the wiring harness I removed. If so... where should I hook it up to?
Now for the alternator:
Do I run the wire from the terminal on the alternator to the fuse block or directly back to the battery or maybe even the starter?
My search found only references to stock wiring harnesses and I am starting from scratch.
