Wishy Washy With V6 Mustang.. And Need Advice
Is remodeling a smart choice?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
RemakablePony
I own my 2000 V6. It's been making an awful noise, and with research I know I need a flywheel and clutch kit. I do have it listed for sale. However, I'm unsure if I really would let it go. I need to know how much I should put into it, before it gets too much. So far, with just the flywheel, clutchkit, and labor to do that, it's 1g. A bit confused, and heartbroken on what to do.
ADVICE????!!!
Noobz347 Thank you. I know just the Mechanic.
Concerning the flywheel, can I use an aluminum standard flywheel versus the SPEC Billit Steel? Is there a big difference performance wise? I'm hoping to save money... I have the SPEC 1 Clutch Kit from American Muscle. Will the aluminum flywheel be fine?
You should be able to reuse your OEM flywheel. Just have it measured and turned.
You need neither a Billet or aluminum flywheel. You need just an OEM replacement 'if' it even requires replacing.
