  • 2005 - 2009 Specific Tech
Won't Start (sometimes)
  • Thread starter Thread starter 07 Boss
  • Start date Start date Nov 3, 2008
07 Boss
41
Las Vegas, NV
Nov 3, 2008
  • Nov 3, 2008
Every once in a while, probably 2 or 3 times over the last 2 months, I turn the ignition key and the dash lights come on and then when I turn the key to start everything either flickers and clicks and the car starts, or everything goes out and the car doesn't start. When this happens nothing works, even the trunk release and door locks go out. What I have done to get it going is to unhook the battery for a few seconds and then everything seems to work fine. I never get any codes or know when it is going to happen. After the first time I reflashed my PCM with the tune that I have in there and it seemed to go OK for about 3 weeks then it happened twice in the last week. Anybody experience anything like this? I hate going to the dealership! I thought that maybe the car was not recognizing the key and disableing the car. but then I thought that it only disabled the starter. It's not a major issue at this point, just a nuisance (resetting the clock etc.) but maybe it is a precursor to something catastrophic.
mrv8outboard
36
  • Nov 3, 2008
clean your battery connections. you have one that is bad. the times it does start it makes the connection due to an arc to complete the circuit. some times it doesn"t.
07 Boss
41
Las Vegas, NV
Nov 4, 2008
  • Nov 4, 2008
Battery terminals are pretty darn clean. only 10,000 miles on this car. There is no corrosion or oxidation on the terminals and they are clamped down pretty tight. I am wondering now if maybe I have a bad battery cable or a bad chassis ground connection. As long as nobody thinks it's a computer issue I will spend more time trying to track it down.
hotcobra03
poteet,tx
Nov 4, 2008
  • Nov 4, 2008
Ford has always had this problem. Put a pre 1982 penny on top off the battery .a dab of silacone will do.the penny will corrode and help keep terminal clean.also dont be afraid off powerwashing engine clean
J
justpball
  • Nov 4, 2008
clean your connections even if they look clean...it is a bad connection on the battery.
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
