won't start
  • Thread starter Thread starter daddyaj757
  • Start date Start date Jan 2, 2007
D
daddyaj757
  • Jan 2, 2007
Hey I am new to this forum and I have done some searching before posting... I have a 73 Mach 1 orig. 302. Just replaced the starter solenoid and we still can't get the motor to turn over, you can jump the posts on the solenoid and it will try to kick over. getting spark to the distrib. We can't figure out what the problem is. any help will be greatly appreciated.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jan 2, 2007
  • Jan 2, 2007
1) Is battery fully charged?
2) What happens when you turn the key?
D
daddyaj757
  • Jan 2, 2007
yes the batt is charged and when you turn the key the solenoid "clicks" but thats it it doesn't do anything else.
M
madbrad
72
Albuquerque NM
Jan 2, 2007
  • Jan 2, 2007
Check your grounds, i had a similar problem and found that the neg battery cable was not grounded properly.
D
daddyaj757
  • Jan 2, 2007
had it grounded to the body and the block still nothing.
M
mustangdave
2,976
North Carolina
Jan 2, 2007
  • Jan 2, 2007
Also, the ground at the block.
D
daddyaj757
  • Jan 2, 2007
yep still good
H
HHStang
566
Coastal SC
Jan 2, 2007
  • Jan 2, 2007
battery or ground
have you tried jumping it from another car? That clicking sound really makes it sound like a battery, ground or the starter relay.
M
madbrad
72
Albuquerque NM
Jan 3, 2007
  • Jan 3, 2007
Just becasue your battery reads 12v dosent mean that it has the amps to cranks the motor. If it a couple years old you should take it to a place where they can test the cranking amps to make sure it is ok. A friend of mine had same problem, we replaced starter, solenoid, batter calbes because the battery was reading
12vs. We took the battery in and it had only a 1/4 of the cranking amps it should have.
H
HHStang
566
Coastal SC
Jan 3, 2007
#10
  • Jan 3, 2007
  • #10
yep,
just like Madbrad says...
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
