Worth having a 302 block machined for 1/2 head bolts/studs?
  • Thread starter Thread starter strtrcr50
  • Start date Start date Jan 16, 2009
strtrcr50
Previously from Dirty Jerzey exit 7a
Jan 16, 2009
  • Jan 16, 2009
I'm getting set to do a budget rebuild on a 302. I have twisted wedge heads, ported gt40 intake, blower cam, and all the rest of the top end stuff. I'm wondering if it's worth it to have the machine shop bore and tap for 1/2 headbolts rather than run the reducers in the heads. Anyone have this done?
2000xp8
SN Certified Technician
Aug 8, 2003
8,031
1,623
194
NJ
Jan 16, 2009
  • Jan 16, 2009
You don't have to physically run actual reducers, you can buy head bolts that have the reducer built into them.
dcurtis
688
Jan 16, 2009
  • Jan 16, 2009
I would just buy the correct bolts as mentioned........
SQUEEZE&STROKE
SOUTHERN CA
Jan 16, 2009
  • Jan 16, 2009
Too much cost for any real bennefit. A quality sey of bolts or studs is all you need.
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
For Sale Mexican 302 Block 60 Over , Comp Cams Roller Conversion and ARP Main Bolt/Head Studs
  • bluelx347
  • May 27, 2025
  • Engine and Power Adder
Engine and Power Adder May 27, 2025
bluelx347
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
G
What's it Worth? ⚠️ I have a brand new set of original KPI/Trick-Flow High Port Cylinder Heads, Stage 2 Ported
  • GhstRider68
  • Jul 8, 2025
  • What is it Worth?!?!?
What is it Worth?!?!? Sep 8, 2025
GhstRider68
G
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
