Would these wheels fit?
  • Thread starter Thread starter Jarrell
  • Start date Start date Apr 10, 2005
J
Jarrell
326
Livermore, CA
Apr 10, 2005
  • Apr 10, 2005
I can get some 17 inch chrome 03 cobras and I was wondering if they would fit on my 67 stang.
The fronts have 275/45/17's and the rears are 315/30/17's.
I know I would need to get the spacers but would they physically fit??
J
Jarrell
326
Livermore, CA
Apr 10, 2005
  • Apr 10, 2005
bump
allcarfan
The Answer Man
2,458
North Atlanta
Apr 11, 2005
  • Apr 11, 2005
what is the rim width? I dont think they are going to fit without some minor mods. 315s are going to stick out a good bit...and so are 275s up front.
12sec67
1,301
San Diego, Ca
Apr 11, 2005
  • Apr 11, 2005
not on the front....03 cobra rims are 17 x 9's. you would hit the upper ball joint.
D
Dr_Pain
69
  • Apr 11, 2005
Front, depending on the backspacing, you can fit up to 245 and I have seen 315 on the back but the car had mini tubs and a 4 link system. I have 255 in the back with a 4.5 backspacing and they have a lot of room...close to the lip though Most likely will bring it back down to a 245 (since I have dropping the car 2 in). If I remember I have a 5.5in backspacing in the front and mounted some 205 (again because I am dropping the car 2 to 2.5 in in the front and want as much clearance as possible). Hope it helps.
Edbert
3,548
32
109
Austin TX
Apr 11, 2005
  • Apr 11, 2005
17X8 front 17X9 rear. get the correct spacers and you'll be fine with any rubber made for those widths. The 315s are too wide I'll say, and 275 up front is a bit much, perhaps 255 front and 275 rear but then you cannot rotate the rubber either.
I say go get a stock set of late-model rims that are all 17X8 and use the stock sized rubber 245/45-17 at all four corners and you'll be good to go, even with moderate lowering.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Apr 11, 2005
  • Apr 11, 2005
If the front's are 8" you can make them fit with the right spacers. You'll probably have to get a smaller tire tho.
The rears will fit, but again you'll probably need a smaller tire.
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
O
Good all around perfornace-ish tires?
  • optionizerSS
  • Jan 25, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
TPony
