for gt40p heads
nstalled: 121 lbs @ 1.800”
Open: 328 lbs @ 1.200”
COMP Cams
COMP Cams Valve Springs
Part Type:
Valve Springs
Number of Springs Per Valve:
Dual
Outside Diameter of Outer Spring (in):
1.430 in.
Coil Bind Height (in):
1.150 in.
Damper Spring Included:
Yes
Spring Rate (lbs/in):
370 lbs./in.
Inside Diameter of Outer Spring (in):
1.070 in.
Inside Diameter of Inner Spring (in):
0.697 in.
Valve Spring Style:
Standard
Coated:
No
Quantity:
Valve Springs, Dual, 1.430 in. Outside Diameter, 344 lbs./in. Rate, 1.150 in. Coil Bind Height, Set of 16
COMP Cams
Part Type:
Valve Springs
Dual
1.430 in.
1.150 in.
Yes
370 lbs./in.
1.070 in.
0.697 in.
Valve Spring Style:
Standard
Coated:
No
Quantity:
