WTF? Foglight Install...HELP!
I am replacing the old foglight with a new one...not the bulb, the whole thing. I cant get it apart- I understand how it is held in there, but cant figure out how to even get the housing off. Anybody with with personal experience? links?
I am stil searching, but wanted to post this incase someone can tell me directly.
Thanks
Isnt there just like 2 or 3 screw that you have to remove and it pops right out? I did this on mine when mine started getting moisture in them. I jacked the front up, unscrewed the screws and it came out.
There are 3 screws. 2 on the top on either side, and one on the bottom. the bottom one is straight-forward, the Two top screws are an ABSOLUTE BITCH to get out. i rolled my car up on ramps and just crawled udnder and felt for the screws to unscrew them because i simply did not want to take off the front fascia.
time
well i took mine off...its not that hard...i was bleeding a lil after wards,....
but all you need is a phillips that is extended...its simple just tke the screws off...o but in my opinion i would use the magnet screw driver better...i should have thought about that my self...good luck...top time for bout..ill say about 30 to 40 minutes...
Thanks all...my brother was helping me. He pryed the old ones out, but its a ****** getting the new ones in right. HOWEVER, when I was putting the screw in the new one to keep it aligned, the top of the "screw whole" broke off. gotta figure something out to keep it aligned...
BTW, I did scrape some knuckle skin off! I didnt realize it was so "simple" to remove the bumper.
Thanks a bunch for all the help!
