V3 Almost!
ok i finally got it!
now seperchargher comes pre filled?,do i drain that and ad new stuff?
they are typically pre filled as oil is needed for the units to be tested, with that said you must also check the oil level with the dipstick in the blower after it is mounted. Don't forget to remove the shipping plug and install the vent in the case.
Sorry about your earlier belt post, I did not realize you were using an aftermarket pulley on the water pump.
that was my fault,i clued out and was thinking backwards!....thanks for all your help guys i got her running!!!
so i want to take it for a short cruise or two before the dyno to make sure everything is all good.....if i stay off the boost and drop timing to 10 i should be ok hey?
Yup . That's how I have done it . Absolutely no boost !!!!!!!!!
As long as it's in the groove straight on the other pulleys I don't think where it rides on the tensioner will affect it
well when the tensioner is not on its straight as an arrow?....but when i put the tensioner on the belt looks crooked to the power steering pump?.....i really dont like that eather,im going to go to the wrecker and see if i can find the liped idler pulley like it used to have and see if that helps
That's what is on mine
ok i took it for a quick rip,seems to run ok with no boost,but it dosnt want to start unless i feather the throttle?,then it struggles to find idle before idling perfect?...i have fuel pressure set a 42psi unplugged,and timing at 10deg?,is this a tune thing?
You went to 42s now right ? This is deff a tune thing . A whole lot of fuel at idle . I'd bet to say if you put your foot to floor (cuts injector pulse) car will start everytime with no hesitation .
Yeah the new 42's are loading it up causing it to be hard to start. I'd back off the FP to around 30-35. That should help. Your dyno tune will add calm to all this chaos. Back when I had my SSC I saw 28psi of fp at idle with the 42's.
Good Luck!
ya i have 42s,makes sense guys thanks,just making sure im nervous!...lol
also whats your fp set at?
Mines at 42 vaccum off
