I wanted to know where this came from or maybe even deteriorated off from my harness. Possibly, even a previous owner cut into wires. Im not a mechanic, but would like to know if this is part of my idle issue. (I know I currently have codes [31,83,84,31]and one time I actually put the EGR vacuum solenoid in backwards because of broken connector and then 83 came and next I put it right so I got 84 next, but I believe 84 came because the computer can now know that it's 84 which is EGR vac solenoid.. right??) As well I had code 23 disappeared after dropping Lucas oil for a while in the gas tank.
Googled it plenty of times to find out maybe it's a speaker connector or iac pigtail, but I also have looked and don't see any connections around like this... Maybe its hidden and you've tackled it before and y'all can be a big help!!!
Green/orange & pink/light blue wire.
