1965 Mustang rust repair
Brian started the rust repair on the right sail panel and rear package tray
Impressive amount of work!
I didnt realize this until recently, but us mustang guys have it relatively easy when it comes to replacing huge amounts of sheet metal. Since we do not have to custom build many patches.
Brian is starting to make a patch for the rocker
The rocker patch is finished and we starting lining up the left quarter and wheelhouse
Brian finished building the right sail panel inner structure today.
Someone tried to remove the ignition switch by prying on it and ruined the opening so Brian cut it out
We replaced the dash in the 1965 fastback because of rust but the area around the switch was good.
After it was welded in and the welds ground down
dimension
Can u tell me where to get all the correct dimensions so when putting a 65 coupe back together I can make sure it is right and goes down the road as intended. right now the cowl is shot, the firewall the mostly gone as are the floors and floor supports. I have the diagram that is in the 65 Falcon/Mustang book but there are not enough of them to make sure it is correct. thanks.
Getting ready to test fit the sheetmetal. The first thing we did was line up the wheelhouse using clamps and screws.
Than all the sheetmetal was test fitted and modified to fit (I forgot to take a picture) than taken off and the wheelhouse were welded.
Next step is to scuff everything so we can spray a coat of epoxy primer
We lined up all the rear sheetmetal as close as we could get it than set the roof on by lining it up where Brian drilled out the spot welds. We had to adjust the rear panel after test fitting the rear window moldings a little. It is quite a challenge trying to line up all this aftermarket sheetmetal that is NOT made like the original sheetmetal.
