Strangely I have never seen it appear in any previous year's MW vids that Ive watched. Not sure how Ive missed it!
Ok thanks.Mike before you start the car again [after the fixes]... you need to start the Warm up enrichment autotune. this will get the AFR on target while the car gets up to temp.
I like trees....And I was just saying that I talked to the walls on the other forum......
Since I was answering build thread questions on other peoples threads I figured I'd talk some more to the paint.
I worked on the hood again today.....Concentrating on the underside in an attempt to blend the G nostrils in better. Once I got that to a point of completion, I spot primed it, and let it sit.
When I built the Megasquirt, I bought DIY's bluetooth adapter so I could connect wirelessly to the ECU. Today I decided to try and get that thing working.
3 hours later, it still wouldn't connect. I hate that thing. While it would be cool to have the capability, how hard is it to actually plug a cable in instead? And how often is it after it's tuned that I'll need to do that? And who else would've sat there for three hours changing baud rates, and com ports, installing, and uninstalling the bluetooth driver and software anyway?
A guy that talks to trees...that's who.
Fck that bluetooth adapter.
He still can.... datalogs are stored in the laptop not the ecu... lol.
Only the ms3 can data log directly, and that's to a USB
The adapter would be cool if somehow you could work a tablet into your dash and have it connect like that so you could mess with it as you drive and not have to d ick with a laptop sliding around. That was my biggest complaint about trying to tune and drive.And I was just saying that I talked to the walls on the other forum......
As long as it's capable of at least windows 7.Would a double din touchscreen unit be able to do the same thing?
