Engine 1991 Ford Mustang LX 5.0 Broken Vacuum Wires Need Part Numbers
tnjmagoo
Colorado
Hey guys. Taking off My intake to do the valve covers and a few wires just stated breaking. I believe they are vacuum wires. Can you tell me the part number so I can get new ones? Pictures attached.
They aren't available anywhere. I used a piece of heat shrink to shrink over the two broken ends and reconnect them. You can also take a short piece of vacuum hose and connect the two ends by sliding one end in each side
I thought the part numbers were BLACK for the black one and WHITE for the white one. :rolleyes:
We are talking about vacuum wires right?
Damn that lights flash'n again, gotta get that fixed. :)
For people in the future that need help with vacuum lines on a Ford Mustang, I got a great answer from a knowledgeable Mustang owner that isn't a comedian and genuinely wants to help.
He said:
"If they're not sold out of it,Autozone sells vacuum lines, the hard nylon vacuum tubing in a few different sizes. Our Foxbodys use either 1/8 or 5/32 tubing.It comes in a package,either in the help section or behind the counter where the spools of rubber hose sits.The package comes with a 3' roll of tubing.The part numbers are listed below.
If you pull the vacuum nipple/elbow off the end of the oem vacuum hose (where the hose connects to the vacuum fitting on the egr valve,intake,fpr,etc,etc) you'll notice the hose end has a raised ridge on it.This prevents the vacuum nipple from pulling off the hose easily.IOW- it keeps the nipple attached to the hose.If your vacuum nipple is loose on the hose,with the new tubing,you can put heat shrink tubing over the hose & nipple to keep them locked together. AZ should have this too.
5/32= #47418
1/8= #47417 "
First of all I'm glad you thought it was funny. Second, there is no such thing as vacuum wires. Now before you get out of breath proof read before you post, it's not that big a deal but there is a grammar policeman here and he will chime in, but thats ok too because it's all in fun.
if it ain't fun, I ain't do'n it!
and smile, it makes people wonder what your up to.
You are going to need this....
The following are diagrams courtesy of Tmoss & Stang&2birds
Vacuum diagram 89-93 Mustangs
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
TFI module wiring for 94-95 Mustang GT
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-IgnitionControlModule.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 88-90 Mass Air Mustangs
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
Starter circuit
http://forums.stangnet.com/attachment.php?attachmentid=21328&d=1080916057
Alternator diagram for 94-95 Mustangs.
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Alt.gif
Buy about 6 feet of standard vacuum line, ponder the routing from source to each component, and re-run them directly, without going through the junction that only served to make assembly easier at the factory.
  • Agree
Reactions: 1 user
