So I sold off my Dart setup and now im 99% sure im going to go with a 3V swap.
Im not going to do anything crazy just a plain old 3v mustang motor with working A/C and power steering. I will also be doing 5 lug swap, I would like to get all the parts in advance so Im going to make a list and If people see things Im missing or want to put input in let me know. I have read some of the 3v swap write ups but everyone is a bit different. Im still a bit confused on how im going to make the A/C work.
Motor - 3V motor (not sure what year i know the later ones
Exhaust- ? probably make the factory headers work with my x pipe
cooling- alum radiator with dual fan setup (controlled with a spal controller or the FMS kit)
Trans/clutch- my TKO600 and Mcleod dual disc setup with new bell housing and flywheel for the 4.6
ECU - Ford Motorsport plug and play kit
Suspension- AJE k member with a arms and Coil overs
Steering- ? help keeping stock interior looks like I need a 4.6 rack
brakes - 94/95 spindles with hydroboost setup convert rear to 5 lug
Unknowns.
Drive shaft - What will work ? maybe custom?
A/C= What compressor should I run and what condenser ??
Want it to fit under a stock hood so Im going to use the MM K memeber spacers, looks like it should fit then.
Power steering pump - Will the s197 pump work or should I run a sn95 ?
Hopefully someone has some Ideas I would like to have everything before I start tearing in.
Unknowns.
