96 Question
96blackgt
Have the 4.6l
When I press the throttle more than 1/4 way, a weird noise comes from the engine that sounds like its running underwater.It's similar to a pinging noise, but its not pinging, however the car was pinging when I was using 87 gas a year ago but ever since I have used 93.
Only problem with the car is that it loses some oil when I go wot a lot, and I'm pretty sure that it's the valve seals. Would that have anything to do with it?
At 130k miles and I plan to keep this car until the motor goes, so any help is appreciated.
The tips should really be kinda brown or a rusty color when running right... White tips normally mean the motors running lean... I'm going to guess the fuel pump is weak but sounds like it mite not be getting enough gas???
Have you had it scanned??? If not go to your local Autozone or whatever and have them do a scan for codes... Could just be a crappy O2 but you never know...
