EEC Relay Location
That's just it. The car doesn't run, unless you physically actuate the relay. Take the cover off, and make it "click". So the control signal is not getting to the relay. That's why I'm looking for the ECC relay
From an earlier post
New to working on a Mustang, so even the most basic help is welcomed. 1990 2.3l Fuel pump problems. If I bypass the relay under the drivers seat, the pump will work and the car will start. When I check the imputs to the relay, no signal. Where does the signal come from? Is there a pressure switch on the EFI that turns on the fuel pump relay. Does it go to some computer. If so where is the computer and what are the pins? Thanks for any help.
Jeepersmitty
