What type intake is that? Did the previous owner give you any info on the car? Do you have any basic automotive knowledge? Need a little help to help you. If you have no info on the car/motor first place to start is to get a vacuum gauge and find constant vacuum around 17 or higher at idle. That will plug into the vacuum tree. You may be able to t that source with the pcv valve. Than check you brakes, should have a better peddle, no hard. Then we can help you from there. Buy a repair manuel for your car and maybe squeez some info from the previous owner. The people here will help you best they can.
