It depends, did you use the proper chemical spray made specifically for MAF's? The sensor elements inside of those are extremely sensitive and can go haywire if you touch it or leave residue behind. I would double check for vacuum leaks first and if the problem persists clean it again to see if there is any improvement. I got a CEL some time ago and after cleaning my MAF thoroughly it went away.
