Two questions:
1. Will replacing these odometer gears cause the car to not start?
2. Is he correct that a Ford dealer can "flash" in the correct mileage? I would like it to read properly once this repair is made anyway.
Thanks in advance to anyone who can answer this!
Hey it's 2017 and I'm referring to this post!!
1) my fuel gauge doesn't work as well. Will replace it the driver and worm screw get all gauges back working?
Hissin50 is still around too right?It's 2017 and I'm still here.
No, it will not fix your fuel gauge issue.
The gears referred to in this post are for the odometer readings only. If your fuel gauge is not working, I can only think of three things 1.) A bad cluster pod that is the fuel gauge. 2.) A stuck float that is part of your fuel pump in the tank. 3.) A pinched/severed wire between the fuel pump assembly to the cluster pod
Don't know. Member search would show his last login.Hissin50 is still around too right?
Sounds like it may be as simple as a blown fuse. User manual will show which fuse in the fuse block controls the instrument cluster. Start there and do a search for instrument cluster gauges/pods not working.Thank you @kartheif
My odometer doesn't work,neither does my fuel,temp,speedometer and oil gauge. The entire instrument cluster doesn't work. It light up when I crank it up though with theft and the battery light but they soon go off when the car is started.
