pin #37
ELGUAPO91LX
47
SOLON,OHIO
On a 87' tc-91' mustang swap, does anyone know what the #37 pin goes to? On the wiring diagrams I have it says its a 12v pin, but when i checked it with a circuit tester I didn't have any power there. So im wondering if this has something to do with it not running, when i turn the ignition to the start position it is starting and even sounds like it is trying run, but as soon as i let the ignition go it just cuts out where it should keep running. any help would be appreciated
No, I don't...if everything was swapped correctly and the motor and accessories were functioning properly before then you should have power their. Did you have any sparks, meltdowns, put the battery cables backwards, etc. sometime during the swap? Do you know the sensors, computer, relay box, etc. are good?
