dmoody said:
>Poor exhaust scavenging(an intake charge which is polluted from the previous >combustion) drops engine efficiency as well as power. (this is why headers and >performance exhaust system add power AND fuel mileage over a stock exhaust >setup)
If this were true then you'd see new honda civics with lumpy idles. Most cars on the street would never benefit from exhaust scavenging. A lot of things that increase horsepower you won't find on cars that get high mileage for good reasons... they aren't efficient.
>If they ground a camshaft specifically to cause just the exhaust side to lose air flow, >the engine's power levels would drop, as well as fuel mileage.
Indeed, in the example given the guy talked about running an 11:1 engine off pump gas. I'm guessing his engine didn't have the same amount power on the street as it had on the strip running race gas. In order to prevent the engine from detonating due to the low octane, you either have to reduce the fuel in the chamber or lose compression.
There is no direct correlation between an engine's power and fuel mileage. If there were then everyone would buy a Mustang Cobra and be getting 50 miles to the gallon.
d
Why would you see Hondas with a lumpy idle?
A lumpy idle means that the engine is getting a dirty intake charge due to large duration valve overlap. When long valve overlap is occurring, both valves are open at the same time, and the engine exhaust stroke is pushing the spent charge out through both exhaust and intake valves. Only when you begin to rev the motor will the incoming air form a moving column of air pressure, the force of which keeps the exhaust stroke from exiting into the intake tract. What I was referring to, is proper(as close to 100% as possible) exhaust evacuation(scavenging) There ARE mechanical principles which add both power AND fuel economy. A cleaner intake charge is one of them.
A more efficient exhaust system, like a clean air filter, is better than free horsepower, it's horsepower with a side benefit of mileage.
Increasing the purity of the intake charge in ANY engine will increase both its power and its fuel mileage. This has nothing to do with changing the cam profile, and everything to do with enhancing the flow characteristics of the exhaust system, starting with the primary tubes of the headers.
If you improve the exhaust efficiency,(scavenging effect) the engine's idle quality will grow smoother, not lumpier.
If you'll notice, economy cars of the past had crappy exhaust systems, and got crappy mileage(and power), whereas today's economy cars have computer-designed and specifically tuned headers, with superior exhaust systems than in the old days, and as a result, they make more power per cubic inch, and get far greater fuel mileage than ever before.
If you decrease the fuel in a combustion chamber, you make the charge leaner, which will generate more combustion heat, and detonate easier than a rich charge.
What you were talking about doing is decreasing the exhaust efficiency of the motor by decreasing lift/duration of the exhaust valve, and by doing so, you're decreasing the quantity of useable oxygen in the cylinder, which makes the charge effectively richer. (Less oxygen = rich condition)
A richer dirtier charge will definately decrease detonation, but at the cost of power and efficiency. Just as increasing the carb jetting beyond an ideal air:fuel ratio will decrease both power and fuel mileage.
