- Nov 12, 2016
- 110
- 2
- 18
I recently replaced my lifters and I can't get my car to run right. The first time I tried to fire it back up it had a hard time turning over (after replaced battery, starter solenoid, cleaning grounds and moving dis. it fired up with a little assist from me pushing the gas pedal). I got it to kind of idle then i went to try my timing light (im pretty positive it no longer is working because it wouldn't pulse on any wire.. The car has an e303 cam (hardened pushrods, 1.7 pedestal mount rockers and upgraded springs). I didn't think i had the timing right so i respiked it at 10 btcd and tried from there but the car still idles rougher than hell.. (it never had this idle issue before.. but the rockers also had lash.... and clattered like hell .. now theyre set right). It still has issues starting I have to aid it with using the gas pedal then it runs but it doesn't just rev up when i push down it stutters and i have to work it up and whole time i can see black out the exhaust.. I've respiked the distributor a few different times.. no luck.. I put new plug wires new dis. cap and rotor... no luck. any ideas?? (I have a tfi module i got about 2 years ago too.. its an accel).
I should add the car has been sitting a year.. I was gonna drain the gas but couldn't figure a very good way of doing so...
