Has anyone figured out a way to get to the fuel pump and wiring without having to drop the tank? Like cutting an access panel in the trunk or expanding the access hole that is there? How safe is it to make the access hole bigger in the trunk? I need to get at the connector but don't want to drop the tank. If I press on the connector I can hear the pump turn on and off so the wiring or connector is intermittent.
I would like advice from anyone that may have done this access hole expansion or any other ideas.
Thanks
Thanks
