Nice garage for sure! Whats that funny yellow car doing in there, lol
How do you have the wheels mounted on the wall?
Thanks. Just basic utility hooks I got from harbor freight.
You could order couplers and piping for it instead of a hose. They are rated for coolant and heat.
The braided hose routes to the bottom of the car so that you can drain the oil for oil changes without making a messIf this V3 is a self lubricated unit which contains its own oil, what it the braided hose for? I'm guessing to aid in draining for oil changes?
come to think of it, I vaguely remember welding on a radiator similar to this to turn the upper radiator connection. It looks as if you cut it you'll have enough room or have someone weld an aluminum 90 on that sucker to turn it ?The snout for the upper hose mount on the rad is 2 1/4" long. Unfortunately I might have to trim it down. I don't want to loose the flared part but I may have no choice. If I do I'll leave plenty of tube to double clamp it. I run a depressurized cooling system anyway so it wont blow off the connection since my cooling system pressure stays low.
two stangs offsets a vette twice over so I get a pass
I've had mine off 4 times with a spacer on it it has 2 gaskets ..... All good brother reuse it .My upper intake gasket came off in fantastic shape. Is it okay to reuse this in a supercharged application?
If in doubt apply a coat of high tack gasket sealant to both sides, it will never leak and the gasket remains reusable. Love the stuff
