94GTLaserRC said:
Keith, (Bishop), where have YOU been
A nice stang like that
and ONLY 3 posts?
Thank you
(I'm at 3 posts already?? Cool!
You need to hang out here some more.
I intend to. I actually joined here a couple years ago, but couldn't remember my user name or password (the email I used then is now my ex-wifes, so I can't use the email notifier to get the old password
I am pretty much a creature of habit and just post over on the corral (4600 posts there and been posting there since 1997
BTW...what is that line that comes off the TB/
Vortech connector tube and runs forward over the top?
That would be my alcohol injection. Still kinda working some of the last little bugs out of this set-up, but its running pretty strong right now (considering at least that I am NOT using my 55lb injectors (got the 36's in right now) or my PMS. The PMS turned out to be the gremlin I chased all this year that was not letting the car run right (had it running like CRAP, to be honest!.) I am currently getting it fixed so at least next year (hopefully) I will be up and running as soon as the weather gets nice (I live in Ohio)
This year I will be going to different gears. 3.73's are jsut too short now with the power level I am at. And also going to do some more
suspension and rear end/axle upgrade. Currently I am running a UPR K memeber and
control arms (and coil overs) upfront, and a
panhard bar, Steeds double adjustable uppers and lowers. In addition to the aforementioned gear change (to 3.27's), I will be doing 70/30's upfront, 50/50's out back, lakewood lift bars, and a heavy duty rear end (eaton, 31 spline mosers, c-clip elminator.) Hopefully that should make it alittle more fun & tractable on the street
What kinda pow'r is that thing making?
Thanks
RC
Haven't had it on a dyno with this combo.
Two years ago it made 422rwhp. That was with a 302, 10lbs of boost and edelbrock heads, stock cam, cobra intake and the usual bolt ons. Tuned via a Lidio chip.
Last year I ran a new 306 with 8.7:1 compression JE's, 15 lbs, added the PMS, and tuned agressively running 110 octane gas (I did have another data set in the PMS for pump, but I never ran it all year
Ended up running race gas the whole summer.) That combo made 475+
This year I have (listed what is different from last year) a Fox Lake built 347, AFR 185 heads, ported lower holley and a Saleen upper, 1 3/4 longtubes, alcohol injection, Aeromotive fuel system and 55 lb low impendance injectors, 70MM TB, Ed Curtis grind cam, and a few
suspension mods (like the K member)
I didn;t even get the car on the road till the first of July this year. I spent I TON of time coming up with some custom stuff just trying to get everything to fit/work the way that I wanted it to. Then I ran it for about a month with out the blower belt breaking in the engine. Then once I got the blower belt on I encountered the PMS gremlin I mentioned. When i finally found the source of my problem, I ditched the PMS and went backwards alittle by hooking back up my FMU (using the 6:1) and BTM along with using the 36's. Without the alcohol injection it would be pretty lean with the 36's and FMU, but the way its "tuned" right now it only goes lean at 5800 RPM's (I data log everything with LM1 wideband I run.)
Hoping that once everything is back on the car and working properly, it will put down something in the 575 range (but with a curve that hits EARLY with allot of torque!
Oh, and to yellow1995Cobra who started this thread, sorry for stealing some of it :OT:
(but at least you got a bump out of it
