What causes a transmission to whine severely??
Kdubslugga
1,515
41
Akron, OH
I have a question. I have a z-code t5 in my car with like 3000 miles on it. Now granted I know this tranny is shot because it sounds god awful, the thing is ive never once power shifted I hardly ever drag race, and I figured all my power, "510" rwhp would break something not wear something out excessivley fast. Tranny shifts very smooth, doesnt grind, but like I said, whines extremely loud. Is the only thing that causes whinning worn out gears? Like I said, im not trying to fix the whine, tranny is getting replaced, just trying to learn something.
Like stated, not enough fluid or the wrong fluid. Might be able to get away with just
changing it for now, but if you've damaged the bearings and possibly the synchros (they tend to burn up and the grooves wear out with low/wrong fluid) you might be better off just fixing it now
Refresh my memory....I know the Z-Spec T5 was stronger…but why? What type of gears does it run? If to strengthen them they went to a strait cut gear set over the standard helical cut gear set, then that's probably the source of your whine?
For the life of me though, I can't remember if that's how they designed the gear sets in the Z-spec, or if they also used the helical cut gears, but made them slightly thicker, with different alloys to improve the strength?
Does it whine in every gear, or just certain gears?
It's helical gearing.
The strenght increase is due to reducing the gear ratios slightly. The materials are the same as the 90+ T-5, but the different torque rating is due to the taller gear resulting in lesser torque multiplication. Also, the pocket bearing was redesigned to allow for less flex of the mainshaft which prevents 3rd gear spread. When gears spread, the load transfers to the thinner part of the gear, which shears easier
It's why the 4-bangers have a lower rating...they have steeper gears, so it allows for more torque multiplication which is when you get in the tooth shearing zone.
Passenger side of trans. There are two plugs that a 3/8" drive rachet fits into. Top is fill, bottom is drain.
With car level, remove the top plug. Fluid should be right at the plug level. If you can stick a finger in and not feel the fluid level, you are low
DO NOT remove the big torx-style plug on the driver's side of the transmission. This holds the 5-R linkage. If you unscrew this, big problem. The fill/drain plugs are on the PASSENGER side
Depends on which parts are scored up.
I had a trans that whined. The 15 roller bearings between input shaft and mainshaft were scored...as well as tip of mainshaft.
Got a good used mainshaft for $75, and a new set of roller bearings for $15 or so...swapped them in and good as new.
If the trans whines in every gear BUT 4th, that's a scored mainshaft. Factor in that shaft as the main replacement part.
Other bearings do fail as well
Non-synthetic ATF is recommended fill....fill capacity is 2.8 quarts (so get 3)
No need to drop trans. Just get it up and level. All you need is a 3/8" drive rachet. Drain from bottom plug into a pan. You can remove the shifter and fill there, but it's quicket to just buy the pump that screws onto the top of a quart bottle and pump the fluid nto the top hole. Will take 3 mins...vs 20 mins removing the shifter.
