4 bolt main windsor block
Depending on who you ask, a Boss 302 could be either a 4-bolt Windsor or a 302 Cleveland. Other than that, no factory 4-bolt 351Ws were made. For that you have to consult the likes of Dart or World(to the tune of $2500). I just picked up a D4 351W shorblock and it looks like it actually has extra material cast in for a second set of main bolts(like my 2-bolt 351C block). Maybe Ford had plans that were never realized :shrug:.
I am not aware of a single part that interchanges between a Boss 302 and a cleveland. Oh wait, some of the valvetrain and valve covers are the same. Still the Boss was available before the cleveland so....
The Boss 302 had 4 bbl cleveland heads, but were modified to let the coolant exit thru the intake. Plug these ports and open up the ports on the bottoms and they can be bolted right on a Cleveland block and used as is.
Way back in the day, Ford made a few experimental 4-bolt 351W blocks. I don't know what happened to them, but they were never used in any production vehicle.
These days you can buy a 4-bolt 351W block through Ford Racing Performance Parts.
the boss 302 was the only production windsor block that had 4 bolt mains. you can install 4 bolt mains on the middle three mains on a 351w as there is enough material in the webs to allow for that. milodon has a four bolt main conversion for the 351w blocks.
You beat me to it! I was going to mention that a quality girdle with quality connectors is stronger than a 4-bolt cap (but a 4-bolt cap with a girdle would be strongest of all of course).
Here's a shot of my DSS Girdle:
I chose not to run a girdle for the fact that they don't save the motor. The intake manifold holds the two pieces together and that is what saves the rotating assembly. Of all the block failures I've read about, none lost the rotating assembly. Girdles help cap walk, but not block cracking. Why would you put a part on a motor for when it breaks? Why use anything other than stock parts if the block will break first? Forged crank and h-beams in a roller block = waste of money, with or w/o a girdle IMO.
Ahh I thought girdles were originally designed to stop the caps walking and thus burning up the bearings and journals. Surely if your engine is going to produce enough power to split the block it is going to bounce the caps first?
main cap girdles doo add strength to the bottom end, and do allow you to make more power before the block splits apart. they are in fact a better investment than 4 bolt main caps. the reason the girdles work is because they tie the bottom end together and change the path in which stress flows through the block.
Nobody said they did save the engine or kept anything from cracking. I said there was a better chance of saving the rotating assembly with one. The block will still split, but you have alot more than the oil pan and intake to hold it all together. Also, if you overpowered 130lbs of iron, would you rely on a chunk of cast aluminum and a piece of stamped sheetmetal to take over? I'm not saying you're wrong for not using one, just that a girdle is an extra layer of potential protection for a block that is likely inadequate for many intentions.
Take valvetrain failures out of the picture and most failures I know of were related to a connecting rod, it's bolt, or a bearing. The crack in the block is usually from the rod escaping :D
DSS built my short block, and based on the materials and tolerances they set they said I am good for 7,000 to 7,750 RPM. I bought a cam that'll peter out at just over 6K.
Thats funny because in various 5.0 forums you hear more about blown or turbocharged roller motors splitting up the middle before the rods fold.
IMO, its good you arent going to use the full "potential" of your DSS. Even the Sportsman 302 blocks apparently crack at less than the old FMS rating of 600hp. I believe roadracers were pulling out the front main web around 450hp and long periods up around 7000rpm.
