cervinis B9 hood DONE
official_style
261
well its on finally! looks real hot. loves it. now for some info. at first, when i was driving, the hood was kinda jiggly where it met the wiper cowl, so i took some weatherstripping and stuck it across the cowl, problem solved. i am a lil worried about those headlight buckets staying on if i go REALLY fast. they are held on with 3m tape and the screw that holds the headlight in. they seem pretty solid, i kinda want them epoxied on, but here is the problem. they cover a little of the grill. so if you have to change the fogs, then i think you will have to remove the bucket, and this would not happen if it was epoxied. there were 2 optional screws that came with them, that go thru the fender. i didnt put them on yet, i want to see if they will stay without. is there any way of changing the fogs without removing the grill?? here are some pix for you all to drool over! so whose stang has the most scoops now? do i win?
pix at bottom.
:nice: what does the front edge of the hood look like on the bottomside? i know it sticks out farther, but cant visualize how. any pics of the underside?
Looks sharp, I really want that hood and ext. Maybe without the hood scoop though. I'm not sure on it, I like the scoops just not sure if I want one or not. I probably won't get one until next year so I can see some pics from the early adopters.
Looking sharp!
That's hot another '05+ done right by the after market, I'm not a huge fan of the new Stangs stock but with a couple mods like yours and some that others have done the can really some serious neck snappers. Good work :nice: U have any larger shots?
no the ducktail does not cover the hood. the scoop is the same size as the original boss 429. why is everyone obsessed with having a functional hood scoop? it will give you maybe 2hp at the max, and will get water and dirt all over your engine. even the shakers do not add any power.
bigger pix! i just got my cam back tonight, tomorrow hopefully its nice and i can take new ones!!
