removing head studs
Pipe wrench???
First of all there should have been zero torque applied to the head studs when they were originally put into the block. All you do is bottom them out in the block and that is it. There is absolutely no need to place any torque on the stud itself. You should have also had some moly lube on the threads.
You should be able to easily back them out with the allen wrench that was provided with the head studs.
If you are using the stock factory head bolts, they are TTY (torque to yield) and are junk once they come off.
Pipe wrench???
What he said....look at the top of the stud there should be some way to grab onto it without damaging the threads....and it should be really easy
i dont think they have an allen wrench top. they are arp studs not factory bolts
If you have ARP studs, the top will look like this:
Another way is to use a jam nut. Basically you thread two nuts onto the stud and tighten the top one while holding on to the bottom one, so it doesnt try to move furthert down the stud. Once they are nice and snug together, you can take a wrench and loosen the bottom nut and the stud will come with it as long as the top nut is not moving. I made a little picture to explain, I am quite bored if you couldnt tell.
