All right guys, I need some advice on upgrading my brakes. I have a '70 w/ non-power disc/drum brakes. My master cyl. needs to be replaced and I've been thinking about converting to power brakes. A friend of mine has a '69 that he is planning on running non-powered 4 wheel disc brakes on.
What I need to know is this:
1) Which is the best set up in terms of braking ability, ease of conversion and cost?
2) If I go with the power brakes, can anybody give me pointers: ie. which set up is good in terms of ease of install and costs? And do I have to replace the current pedal, dist. block, and/or lines?
3) If I were to go with the 4 wheel discs, same question as above and is it possible to use my front discs in the rear and run larger discs up front (I believe the front disc conv. is a Granada set up)?
I appreciate any advise! Thanks!
