tranny mount mayhem
NKau
1,346
Jefferson, WI
I've had an ongoing problem trying to figure out why my tranny/engine sit a bit cocked in the car, slightly pushing the shifter handle over to the passenger side of the car, and not allowing the stock bezel/shifter boot to go back on (been this way since I've owned the car).
It appears to me that the actual tranny crossmember or mount itself is causing the location problem. Are either the crossmember or mount offset? Would it be worth maybe trying to flip the tranny mount or crossmember around? I'm really at a loss here; anyone who's had or seen this problem please chime in.
That's the thing; the offset isn't really that severe, but just enough to screw up the shifter location enough to where the stock shifter bezel won't fit over the base of the shifter mechanism, and I can't imagine it's good for u-joints or the tranny's tailshaft either. I'll have to take a look and see if I can find some marks on the crossmember. Anyone else?
Upon further review, it appears the crossmember must be wrong altogether?! It has a bigger hump, but when the crossmember is flipped with the bigger hump to the drivers side, the shifter is pushed even further toward the passenger side; obviously not right. With the crossmember out and the motor mounts loosened, I can get the tranny pushed over to where it should be, but the slots in the crossmember are about 1"+ closer to the passenger side of the car than they should be. I am at a total loss here. I'm afraid to order another crossmember and have the same problem. Is there a company that makes some kind of adjustable crossmember? I'll try and get pics of what's going on to make what I'm talking about a little more clear.
how close does it sit to the pass side??? I'm pretty sure the natural location is offset slightly to the pass side, that's what I've seen in all my stangs so far. I was just under my parts car a couple of days ago. I think, actually the bigger side goes on the pass side. if your boot won't go back on, that is a problem. Something is def not right. You could try oblonging the holes in the trans x member to slide the trans over a little, but that may be a bad fix. I'd look at your engine mounts first to be sure they are not collapsed. It may be your engine that's cocked to one side.
helix007 said:
check your motor mounts...or better yet buy some new ones.
Exactly! The shifter was cocked slightly to the left when I bought my 95 GT. I discovered the motor mount was totally broken on the driver's side causing the whole driveline to tilt slightly to the left. (not to mention alot of vibration while driving!).
I installed new motor mounts and everything now lines up nice and straight.(much smoother too!)
Cheers
WOW; thread back from the dead. No, I still don't know exactly what's going on. New motor mounts helped quite a bit, but did not fully take care of the issue. The shifter still does not sit squarely where it is supposed to.
