Did I Get Robbed?
GSXRMIXXER
97
i purchased some used axels for my 88 GT to complete my 5 lug conversion for the rear end. What is that big gear on the end of the axel? The guy said these would work for the conversion. they're 28 spline (i counted) and 28.6" long or something like that. did i get robbed? if not, do i need to use the rotors or can i just purchase 5 lug drums? please Help if you know!:shrug:
oh yeah the rotors the guy gave me were 11.65"
that is for abs brakes. i do not know if you can just ignore it. i got the 2 passenger(i think) axles from a ranger 7.5 rear end for my 8.8 and that wasn't there. my guess is that it will be o.k. just your rear as long as the rear width isn't to wide to hit the fenders.
i did have that gear thing on my 6 lugs front rotors and i could just ignore it.
Looks like you got a hold of some 94+ axles. They're a little longer than the ones you'll be replacing, but they'll work. Those are the exciter rings for the ABS on the car the axles came from, so you can remove them.
No, if they are 94-98 axles you really can not use drum brakes with them. The drums would sit about 3/4" too far off the shoes. It would fit, but it would not be a proper installation. Oh, and you got the Cobra rear rotors with them. Either get some Cobra brackets and rear calipers for those axles, or find some PS Aerostar/ DS Ranger axles and use the 5 lug 9" drums with them.
thanks for the helpful info now a couple questions. Which brackets and calipers do i need because i decided to convert to disk brakes considering i already have the rotors? Will other calipers and caliper brakets from any other vehicle or model other than a cobra work? Did i get a good deal for $150 (rotors and axels)?
doesnt sound too bad. a j/y wanted $100 for 2 ranger axles with nothing else when i was looking.
yeah here in california (San Diego) i can get ranger axles for $20 Ea. but this guy said these were superior axels that's why i paid that much then, to my own fault after i got home noticed they were OEM parts!
With those rotors, the only brackets that work are the Cobra brackets, since they are necessary to properly position the calipers. The GT and V6 brackets are shorter since the rotors are only 10.x" across. You can get them from Ford, but they are probably like $50 each. Best buy is the Cobra conversion kit for $175 or so from www.buyfordracing.com . It has the brackets, dust shields, anti moan brackets, and rotors for that price. You can use the Cobra rear calipers they sell, or the V6/GT calipers, but the V6/GT ones need to be ground down to fit over the thicker Cobra rotors. Matt's website has all the info you need - http://sn95brakes.com
thanks man, so do you think i should just buy the smaller rotors and save a little bit of hassle?
It's the same amout of hassle really
Here's the kit you want for the rear CObra conversion.
http://www.buyfordracing.com/shop/product_info.php?products_id=477
I know you have rotors, so you can sell the ones in this kit for $100 or so and get some of your cost back. The kit is complete except for calipers, and brake lines.
You can leave the ABS rings on the axles. They are not going to be in the way of anything.
For calipers, any 94-04 rear caliper will fit. If you get a GT/V6 caliper you will need to grind the slot that the rotor passes through open slightly and run the thinner Cobra pads (or worn Gt pads)
You should also upgrade the front brakes to match (either 13" or 99-04 10.8" GT 2-piston PBR) and you will need to make MC changes and install an adjustable prop valve.
Unsure if you have read this page, but here it is
www.sn95brakes.com
