351 efi distibutor?
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
i am trying to get a distributor for my 351 build. and all i can find is the efi truck ones with seperate wiring for th pip and a seperate wiring harness for the tfi. the parts store has one for a 89 ford truck witha 351 and efi and it looks just like my mustang one where all the connectorers plug into the tfi and the tfi plugs into the bottom. will this one work? i cant afford a msd unit and ther advance auto one is way cheaper. i just need to know if the 1989 efi will work. should the 1989 351 efi distributor be longer?
MSD 8452 with roller cams , 8453 with non roller cams , dont skimp on the distributor if you are going to spend the money on doing the swap to begin with
88 model F150 should have had the module on the distributor , but the gear on it will be for non roller cam engine so you will have to change the gear to run on a roller cam
the 85
so im assuming the 85 isnt a roller motor? how much HP can you get out of a hydraulic cam and lifter motor? cause i have a procharger off of my current setup and i plan on turning the boost up pretty good when i get this thing together. will i be safe with a hydraulic motor? or do i need a roller motor? and if i do what year, make and model vehichles did these come in?
attachment.php
The late and mid 90's trucks had 351W engines with roller cams. 351W blocks that are roller cam compatible have the casting number F4TE located near the starter.
distributor
i have a 1985 motor so its not a roller motor and a 1989 efi distributor which im guessing is the non roller distributor. so if i want to upgrade to a roller motor later do i have to as mentioned above change the gear and if i do how can i obtain just the gear? and i measured today and my new 351 dist and my 302 dist are the same length but the 351 dist has a wider shaft. are they supposed to be the same length?
attachment.php
Excellent post JR :nice: :nice: :nice:
Well put.
something is wrong.
the 351w dist should be about .75-1" longer. (I don't remember exactly).
You can get the roller dist gears anywhere. Summit, Jegs, local parts stores, etc.
They will need the diameter of the dist shaft (I think there were 2 sizes used on the 351w, so measure yours).
jason
parts store
yea i ordered a replacement distributor for a 1989 ford truck with a efi 351 and i measured the length from the base where it sits on the intake to the top of the gear and it was 3.5". it was the same on the 302. can somebody tell me if this is the correct length or if the distibutor i compared the new 351 piece to isnt for a 302 perhaps.
any numbers yet?
does anybody have any measurements for me? what imk looking for is a length from the base of the distributor where it hits the intake to the top or bottom of the gear and an over all shaft .length
DISTRIBUTOR PROBLEM SOLVED
HERE IS A LETTER I WROTE TO VRISTANG HOPE THIS HELPS SOMEBODY OUT THERE,
ok i got tired of waiting and went ahead and bought an MSD piece. so the verdict is, get ready for it.....THERE THE SAME LENGTH. i know, i know your thinking deck height and all that but its basic geometry(i will come back to his later). so anyways i got the dist in from msd and have the one out of my 5.0 302 and measured them with a caliper and the base to gear length are the same length. the only difference is the shaft thickness. i thought maybe i got the wrong part so i called MSD's tech support and the guy was nice enough to put me on hold and go pull the parts and measure them while on the phone with me and he got the same measurements i did. and i know people (maybe even you) will try to argue me down about it but its right. i put the distributor in the 351 and it fits. its currently not running becaue iam putting on better heads as you saw in my thread but it does work. the shafts are thicker and thats it my 302 shaft measured(with a caliper) .28125 and my new msd 351 shaft measured .53125 so ruffly a 1/4 inch difference or 1/8th all the way around. i have a drawing but have no way to attach it since it was done in autocad but i will try to explain it. its a v shape it gets taller but also gets wider so the top to base line dimension doesnt move just the height and lengths. if you can give me an email i can send from my email i will make a DXF file of it and send it to you. bottom line the are the same length just different shaft thickness's. i dont see how nobody as caught or researched this before. but i have done the research and have compared the two parts side by side and got accurate measurements. i will try and make a tecnical write up on it and make a MS paint drawing to better explain it and maybe it can go in the stickies to help others in the future. and i know im gonna catch a bunch or crap saying im wrong but i know whats right if you want i can get pics of the two side by side and give you part numbers off both pieces and let you see, or maybe you can measure yours in your shop and see for yourself. if you want me to explain or want any proof just let me know. thanks, Keith Cauley.
AND THE MEASUREMENTS ARE NO WHERE NEAR CLOSE ITS JUST AN EXAMPLE!!
Very very interesting BK. I don't think people will try to argue you down, or they shouldn't since you did all the footwork. Just make sure to check for distributor end play when you install. You don't wanna screw up that nice MSD piece if you are going to install it. Been there done that, paid for another one.......
It shouldn't be a surprise that they are the same length because the timing chain cover from a 302 fits a 351w. The deck hieght is where the heads mount to the base of the block that is the difference between the 2 engine blocks.
yep
that what i was thinking, and thats what my little drawing is showing. i have had so many people say they are 3/4 and 1" longer and it just wasnt adding up. so i felt like i had resovle this matter. im surprised no body has tried to disagree with me yet. i just got through with a nice little write up on how and why. maybe one of the moderators will put it in the stickies. cause i know a bunch of people wanting to do the swap will need to know this. and if anyone on a budget needs a distributor you can get on for a 1989 f-150 with a 5.8 thats the only year that will work. and if you want to run the roller 351 you have to change the gear, i have all the part numbers and what not if anyone needs them. and contrary to belief the lightning distributor will not work. the p.i.p and t.f.i are controlled seperatly, as where our cars p.i.p signal runs through the t.f.i module.
86bluecobra-thanks for the head selection advice. i got a set on the way.
