Can my edelbrock heads keep up with a 331 or 347 stroker? Will they be the item that chokes the motor? I have a brand new 600 cfm holley, will this be adequate or do i need a 750 cfm.
If you think about it, a 2.02 valve really isn't a whole lot more than a 1.90........ I think you'd be fine with those heads. The 600 cfm Holley should be adequate as well.
AFR 205 heads, Comp cam XE282HR. The eddy's r too small for a stout 331/347. With 10.7:1CR and this combo and the right carb, easy 375-400 @ the RW, NA
