hey guys, im using a 7.5" rear end out of an 84 SVO, it had stock t-loc and now im guessing that its worn out... so i just want to verify...
the car was running perfect and then i parked it the other night on a slightly downward hill (nose of car pointing downhill) and when i went to reverse it out of the parking spot, i let out the clutch and the car seems like it just nudges backwards and then stops... if i give it gas it just revs and makes a slight squeaking sound.... the driveshaft is turning, so it must be something in the rear, correct? even if i put it in first while holding the brake and let the clutch out, the engine doesnt die, just kinda hear a squeaking from under the car....
im assuming since it nudges backwards a little, and since i didnt hear anything break, that my tloc is just worn out and slipping... whatcha guys think??
