Top End with only Holley/Edel
DRock9
359
I can get really good deals on all Holley/Edelbrock and MAYBE Ford parts, since I have been intending on buying the whole Top End as a kit I have not had to do any research myself as to what combo's work good together. So I am coming to you all for help since I don't want to guess on this and I need something that works good and pulls hard in low RPM's, this is going to be a street car but also raced at the track. I would like to keep everything around the same price as a TF kit so ~$2,300. I will go look on summit to see what parts I can try to put together myself but I still would like some reccomendations from people more knowledgeable than myself.
Thanks!
EDIT: What annoys me is that the Holley Systemax kit comes with only half of the stuff the Trickflow kit does but costs $200 more!
pulling HARD down low usually means not pulling hard up top...best low/mid cam IMO for the street is the stock cam. Any OTS cam is going to be more mid/high end orientated...you could go custom to suit your needs. Why not just go with the holley kit? or the Eddy kit? or for the money you want to spend get the TFS kit...they all make realatively the same numbers and cost is simular as well.
I have had both the holley kit and the edelbrock kit now. In my case and experience, it is apples to oranges in comparison. The Holley kit on my 306 screamed and really shined in the upper RPM range. The Eddie kit I have now on my 358 seems to be a little more street friendly, but really doesn't seen to have the almost endless top end the holley did. Either way you won't be disappointed IMHO.
So DMAN you're telling me to just leave the stock cam in there and upgrade only the heads and intake? This car will also be on juice, 150shot, until I get the funds to get a SC.
I would rather spread the power from Idle-6,000 RPM and have most of the power come on at about 2,500RPM.
I am looking to make a purchase soon and I just need the best matched Edelbrock/Holley parts for my street application. I cant guess on what I need when it is going to cost me an arm and a leg.
Thanks for the help!
EDIT: It also seems to be my understanding that I should expect 300rwhp from relatively any HCI combo correct?
You stated you wanted low end grunt..I assumed you wanted to retain the low/mid power that the stock cam shines with...if you want 2500 plus to 6000 RPM power...then you can look at an aftermarket cam either an OTS or custom. Stock cam is excellent on the street and if your going blower later then likely you should wait to go with a blower friendly cam when the time comes. I'm confused by how you mention the TFS kit and it's price but don't consider it as a possible purchase item...the package works pretty well and will run with most any HCI combos out there.
I stated in my first post that I get really good deals on Holley/Edel stuff but not trickflow sadly.
I want something that very closely mimicks the TF Street Heat characteristics, the max I want to rev is 6,500 so nothing that requires more than that...I want it to feel fast in the low RPM for DD but still give me 300whp and 12's at the track.
I usually shift at 1,500 RPM anyways so I am not sure if I should go with more mid/top and that is why I come here.
Thanks a lot!
holley heads have had valve guide wear issues in the past , so there for with the heads I would say edelbrock even though the holleys slightly outflow the edelbrocks , as far as the power being in the low, mid or upper RPM that will be determined more by the cam and intake than the heads ....why not run the edelbrock heads with a holley or cobra intake and run a trickflow stage one cam ....that would be a good combo for sure ...... im personally running a 306 with a cobra intake , X cam and edelbrock performer RPM 2.02 valve heads and its running high 7s on motor in the eighth with 4.10 gears and 11 to 1 pistons .......its pulling the drivers tire 2 inches on launch on drag radials .....
I am not going to do anything to the bottom end of my motor, if I have to I will just keep it all stock and spray the hell out of it. I will go look around and see what kind of intake I should run...this is all very new to me.
Thanks!
EDIT: I would rather go with a Holley/Edel over a Cobra, it seems to me like they would give me more power than something that came stock on these cars back in 1993.
Would a Edel Intake be better than a Holley for my application?
Honestly the TFS kit is better in the mid to high end. I think this is largely to the intake though. Edelbrock and the GT40/cobra/explorer intakes seem to have the best low end power if that is what you are looking for. Given your choices and your cost of items, I would go for an Edelbrock over the holley setup.
Kevin
After some thinking, I want more power up top because when I race the RPM's don't go below something like 4k...and I realized I don't care about the low end grunt because when I am not racing I shift at no later than 2,000RPM...I just don't want to rev it above 6k-6.5k.
It seems like I am going to be buying this in pieces and not as a kit so buying only the TF Intake without my discount may be an option, I am going to do some more researching and see what tried and true combo's there are before I make my decision.
Thanks for all the help, and feel free to chime in with any additional input!
If you have to buy a kit I would go edelbrock.. If you eventually buying a blower and are piecing things together I would go Holley intake, blower cam, and edelbrock heads( since you want to stay within holley or edelbrock.)
The probable reason you feel like the Edelbrock isn't 'shining' on top is that 358 you have pulls more air in at a lower rpm with the bigger cubes so therefore uses the heads/cam/intake potential much earlier than a 306 would.
The Holley, Edelbrock, Trickflow kits should all perform similar with similar camshafts.
Nice post though:nice:
What kinda cam should I use with a nitrous setup? I am going to go nitrous until I can afford a SC...which would be a LONG ways away from now.
EDIT: Edelbrock makes an EFI kit right? The only one I can find on Summit is the carbed one.
