I have bought a 94 stang with a 302. The motor has been bored .60 over. I bought it broken, but not from over heating, one of the valves got bent and the piston beat the hell out of it and you can guess the rest. Well, had a sleeve but in and honed it. i was able to save the head as well, the shop were I had taken it tig welded it and machined it out. Thank god because the heads are AFR, can't remember what series. With all the stuff on the motor I have match in the Summit catolog the guy that had it spent some dough. 302 .60 over BBK cold air intake with mass air flow sensor. Edelbrock manifold upper and lower if that sounds right,AFR Heads,Tremic Racing 5 speed,Headers can't tell what brand they are,303 cam not sure what series,Had DSS pistions but I am getting a new set,The guy I bought it from said that it had a high volume fuel rail if there is such an animal, and it had the red injectors have heard that the color means something and have heard not,MSD coil. However to make sure I am going to upgrade the water pump and oil pump, as well as the radiator. Along with a performance t-stat. I thought about going gear to gear timing on it as well. I am new to this tearing down and building up. I have read and read but you can't ask books questions, so I am also new to the forum. I am assuming that there was no over heating issues due to the fact that its a 94 and two owners since the mods. I hope that is a sign that the block is a good one. The machinist said the reason for the valve issue was oil flow. I have read that when you sup up the horse power its a good idea to also upgrade the oil pump like the shaft especially, due to higher torque and the shcok one twisting. it was in one piece,but it crossed my mind that the supply was less than the demand because of the horse power. Well any input would be helpful..so here i am lay it on me.
