a friend of mine might be giving me his stock rods and pistons out of his 03 cobra. which is great but i have some questions. what cc is the 03-04 pistons? what compression would i be with P.I. 2valve heads? is my cam choices changed since there might be less clearence between the valve and the piston? would it be wise to go with the cometic head gaskets to reduce compression? if so what cams would you recommend? thanks alot, jason
