is my solenoid bad or my starter? hot starter wire??
67boo2
39
Last weekend I started the car and heard nothing but a TICK. I took the key out and started it again and fired right up. Now this past weekend all I got was TICK. not turning over nothing...Optima Battery reads 12+ volts and the main starter wire was HOT...
well with a starter solenoid, a single click usually means DEAD battery, lots of clicking means low battery. I would double check your connections on the battery and the grounds to make sure you have a good ground.
+1, get the battery tested at a parts store and you can rule it out. Next in line of dying is the starter, go there next.
Wes
Hot wire means a bad connection somewhere. Check the connections......especially the grounds. Take em off........clean em......reinstall and see how it works.
Battery at 12.5 is good.........need a load tester to see the condition. 13.7 to 14.2 from the alt when the car is running.
Is the cable that is getting hot the cable from the starter to the solenoid? If so, it carries a chassis ground from the body through the starter to the solenoid. The hot 12 volt cable from the battery to the solenoid makes a connection through the solenoid when you turn on the ignition key which spins the starter. As others have suggested, I would check for loose wiring first.
Update w/ Vids
I cleaned my 4 month old battery cables and the main starter wire (solenoid to starter) and tighten all the connections. Still no hope
Start up #1 You could hear a whine coming from the starter
<embed width="430" height="389" type="application/x-shockwave-flash" wmode="transparent" src="http://vid14.photobucket.com/player.swf?file=http://vid14.photobucket.com/albums/a329/p10socal/mustang/Stang002.flv"></embed>
Start up #2 notice my fan barely moving but started. got 14+ volts while running
<embed width="430" height="389" type="application/x-shockwave-flash" wmode="transparent" src="http://vid14.photobucket.com/player.swf?file=http://vid14.photobucket.com/albums/a329/p10socal/mustang/Stang003.flv"></embed>
Start up #3 just a click Smoke actually came from the starter
<embed width="430" height="389" type="application/x-shockwave-flash" wmode="transparent" src="http://vid14.photobucket.com/player.swf?file=http://vid14.photobucket.com/albums/a329/p10socal/mustang/Stang004.flv"></embed>
Any reccomendations? Should I just go ahead and get a starter?
Iskwezm, I went out and put the meter on my battery that I charged and has been sitting since Sunday ( 2 and 1/2 days): 13.8 volts. :shrug:
Thats great.
Like I said, a fully charged battery at rest is 12.5 volts.You "forced" (possibly overcharging)a charge on yours which gave it higher then 12.5V.My dual battries will read 14.8+V when they are charged but will drop down to 12.5 after a load is put on them.A alternator will regulate the charge they get and thats why they wont read that high when they get a charge from the alternator..Im just stating what I learned after 8 years of being a Ford Certified Master Tech.
ISKEWZM is correct. Not that he needs my backup, but I've tested more batteries (and probably dealt with more Optimas) than I can ever remember.
12 volts is FINE for a battery. Typically the accepted range for an alternator while charging is 13.5-15.5.
And not to be a pain, but it's 12.6 that's fully charged :D Clearly 12.5 is fine too.
There are plenty of sites that explain everything. Look it up.
All done!
:D
Well it was the starter all right. I brought the starter to Kragen auto parts and had my starter tested which came out to be trashed. So i bought one for $35 installed it and starts like a champ. The top bolt gave me problems, but do-able...
Thanks for the support..
