computers
93 notch_coupe
I've been reading all this stuff on computers and i would like to know if i have to have mine reprogrammed i have a 93 5.0 and did a h/c/i and tb and have some header issues with the #1 and #8 cylinders (getting red) and the timing is correct and i had a mechanic tell me today that the problems would never be solved until i had my computer reprogrammed or a custom chip made to make up for the added air and i have not done any fuel mods. i need some info on this cause i can't drive my car until i get this fixed.
First, and foremost, find a new mechanic. Second, what are your mods? Before someone else comes along and makes the request, you should create a signature that lists your mods. It makes things easier when trying to help solve problems, and gives you some bragging rights if you have some nice work done.
finding a new mechanic is a good first step lol
First, pull the diagnostic codes. They may not reveal much in this instance, but this is always a good place to start...
A couple of things can cause hot headers...
AFR, ignition timing, valve issues, etc.
What h/c/i did you install? (your sig is a good spot to list these)
What is the timing set at?
Where all the parts new?
jason
heres all the info on parts, trick flow h/c/i, 65mm tb, bored .30 new trw forged pistons new rod and main bearings. the fuel system is all stock, 19lb injectors and stock fuel pump, but i have a holley fuel pressure regulator. the timing is at 14* fuel pressure at 40 with vac off. if i leave my computer stock can it handle these mods, i really don't understand about custom chips and computer tuning, i really need some help because my car is worthless right now.
You should not need a custom tune on that combo.
The problem is elsewhere...
Pull the diagnostic codes from the computer as this should provide a good starting point for troubleshooting.
Good luck,
jason
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
index.php
attachment.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is less than $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
what will that actually do for the car, and how do i actually read the codes i really don't understand how to do this.
It won't do anythig for the car, but it will give the car an oportunity to tell you what might be wrong.
The EEC-IV (the computer in your car) has the ability to record when a problem occurs. It records these problems as 'Trouble Codes' or 'Diagnostic Codes'
Using the methods outlined by JRichker will allow you to retrieve these Trouble Codes.
It is well worth the time to learn how to do, or the 35 bones to buy a scanner.
good luck,
jason
